Browse Forums Flooring & Floor Covering 1 Feb 16, 2009 6:04 am this is the plan
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ this is the specs 21. FLOOR AND WALL COVERINGS Carpet: Included as selected from builders range (refer colour selection) Allowance carpet per Broadloom meter - $80.00 supplied and laid Tiles: To areas as specified in the following. (Area sizes mentioned are approximate, dependent on tile module size selected. Colour of grout to match tile colour). Allowance tiles per mtr - Floor tiles $22, Wall tiles $18 ceramic tiles laid on adhesive Tile sizes for floor are 300mmx 300mm and for wall tiles 200mmx 200mm by default Meal area = tiles living = carpet if i want to have tiles for the living area as well..will it end up to be more expensive? Re: carpet vs tiles 2Feb 16, 2009 6:55 am If you stick to the standard included tiles, it should still be around $30 per metre cheaper. When we had our $22/sqm tiles deleted off our tender, the amount we were credited worked out to be in the range of $48/sqm.
What you have to ask yourself is will you be happy with the incuded tiles? Normally they're not very nice at all. Included carpet tends to be nice enough. Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: carpet vs tiles 4Feb 16, 2009 7:27 am I'd definitely tile the family room even if it cost extra.
cococrunch, just a suggestion, I'd tile the passage between bed 2 and bed 3 as well. It encompasses wet areas (bathroom, laundry) and will be a high traffic area and the carpet will wear out very quickly. I'd also tile the front entry way if you aren't already. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: carpet vs tiles 5Feb 16, 2009 9:17 am We have put carpets in all the bedrooms and tiles for all the other areas like living, theatre, formal lounge because of the reasons mentioned by Jo.
I would suggest put tiles in living. Puting tiles in the walkways would be a wise one too.. Re: carpet vs tiles 7Feb 17, 2009 11:53 am anny We have put carpets in all the bedrooms and tiles for all the other areas like living, theatre, formal lounge because of the reasons mentioned by Jo. I would suggest put tiles in living. Puting tiles in the walkways would be a wise one too.. Is your home theatre room enclosed? Surely tiles would make an awful echo/hollow effect. Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: carpet vs tiles 9Feb 17, 2009 12:13 pm anny yes we have doors for the theatre.. but i dont find ne echo or hollow effect!!!.... May be coz we have a rug there .. not sure Yeah the rug might break it down a bit...I just thought a tiled floor in an enclosed room would play havoc with the subwoofer, especially. Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com 1 15697 1 10973 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6565 |
