Browse Forums Flooring & Floor Covering Re: How would you order and install your solid timber floor? 41Mar 01, 2009 9:29 pm Beast, that floor looks great! What grade is this?
Do you mind share with us which installer you used? Thanks! Building Clarendon Brighton - Done and moved in Sept 2009 Re: How would you order and install your solid timber floor? 42Mar 02, 2009 8:41 am Jochicho Thanks for that info Dukemaya, I guess it's worth investigating, the only problem is that I think most layers won't be up to speed with this new technicque as most people we spoke to they still do top nail. Are you sure you don't do any work in Sydney? Unfortunately things like this do take some time to filter through to the mainstream 'market' You could contact Boral to see if they could put you on to anyone or try the NSW assoc. of timber floor installers (can't remember the exact name) Re: How would you order and install your solid timber floor? 43Mar 02, 2009 11:34 am eho Beast, that floor looks great! What grade is this? Do you mind share with us which installer you used? Thanks! It is select grade. I used a guy called Larry McCully. He is an active member on another renovation forum. 19mm or 12mm ? 44Mar 10, 2009 9:42 pm Has anyone used 12mm T & G over Ply? I know this is often called "overlay" and in most places it is described as being shorter lengths (under 2.4m) for ease of transport and apartment installation. But my builder swears that he can get a 12mm product that comes in long lengths like 19mm. I can appreciate I do not need to span joists and so the 19mm seems like more thickness than I can ever use. And obviously 12mm is going to be cheaper. Just wonder if I am being spun a line.
Like others here I have been leaning towards purchasing the timber independently and hiring a separate specialist to lay and finish. I really appreciate that other here are struggling with these decisions. It's a big commitment, that's for sure. Blackbutt floor 45Mar 11, 2009 12:00 pm Beast your floor is beautiful! What finish is that? We had cypruss pine with polyurothane in our previous house, and I hoped for a different finish this time on our blackbutt, but husband loves the very shiny finish, and I love it too so that's what we'll be having. On another note, we've been told the concrete needs to have a moisture barrier, painted on I think, before the timber goes on. Have you heard of that? Re: 19mm or 12mm ? 46Mar 11, 2009 6:14 pm Dozzer Has anyone used 12mm T & G over Ply? I know this is often called "overlay" and in most places it is described as being shorter lengths (under 2.4m) for ease of transport and apartment installation. But my builder swears that he can get a 12mm product that comes in long lengths like 19mm. I can appreciate I do not need to span joists and so the 19mm seems like more thickness than I can ever use. And obviously 12mm is going to be cheaper. Just wonder if I am being spun a line. the 12mm overlay is not any cheaper than 19mm, its main benefit is it can be laid over 12mm ply thus reducing the overall height - 19mm T&G must be laid over 15mm ply minimum. Hurford Hardwoods produce a 130mm x 15mm secret-nail wide board. Re: How would you order and install your solid timber floor? 47Apr 03, 2009 9:21 am Hello Eho, I know you are building a C home like us close by. We are planning on ordering the timber directly from a timber mill in Ashby, NSW. around $40 SQM + delivery I have found a layer who is good and also a finisher. I can give you the details if you wish. Lobo Buildling a Clarendon Crestmead in Sydney DA Approved on 20/03/2008 Slab Poured on 02/09/2008 Frame Completed 15/10/2008 Brickwork Complete 2/02/2009 Roofwork Complete 05/03/2009 Re: How would you order and install your solid timber floor? 48Apr 06, 2009 11:57 am lobo Hello Eho, I know you are building a C home like us close by. We are planning on ordering the timber directly from a timber mill in Ashby, NSW. around $40 SQM + delivery I have found a layer who is good and also a finisher. I can give you the details if you wish. Lobo Oh yes pls!! Which species are you getting? Building Clarendon Brighton - Done and moved in Sept 2009 Re: How would you order and install your solid timber floor? 49Apr 07, 2009 11:03 pm Hey Lobo, I would love it if you could also pass me the details of the Mill and the layer, how far are you from getting the floors done? would love to see pics! what timber are you going for? Building a Wisdom Prosperity 23 - http://erwisdomprosperity.blogspot.com/ Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39753 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 10352 |
