Browse Forums Flooring & Floor Covering 1 Feb 07, 2009 5:32 pm reading through the Boral hardwood flooring brochure it mentions that
"Evaporative cooling systems should not be used where wooden flooring is installed. Such cooling systems, through intermittent use will result in large fluctuation in humidity. This may result in deterioration of the wooden floor through exposed to repeated wet/dry cycle, and an increased potential for splintering." Does this mean that timber floor should not be installed in a house with evap cooling? timber 2Feb 07, 2009 6:04 pm I think this is really more relevant for a venue where the air con is on all day every day - maybe a commercial place. But I dare say that it's a problem for any cooling, and no one will live without cooling!
Annie A thankful person is a happy person. [/color]My hobby design blog: http://aviewondesign.blogspot.com/ Re: solid timber floor & evap cooling 3Feb 11, 2009 7:03 am I wouldn't have one due to the amount of water they put into the indoor environment. I see too many mould issues related to evaporative cooling and I would imagine that the huge fluctuations in moisture content could cause some issues with timber. cheers Col Nation For information on caring for wool and other carpet and upholstery go to www.woolsafe.com.au Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15922 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8321 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3280 |
