Browse Forums Flooring & Floor Covering 1 Jan 24, 2009 9:08 pm We are on a tight budget but still want real timber floor in the lounge and kitchen. We thought is would be cheaper to buy 2nd hand timber flooring from a demolion timber yard.
Does anyone know of the cost, savings and any problems doing this. We would be laying it with a help of a builder friend. Re: Second hand timber flooring 2Jan 25, 2009 7:42 pm You can get timber flooring very cheap through the auctions if budget is very tight.
That being said it can be bought fairly cheap anyway, we have 80mm feature grade stringybark for about $33 sq. metre Re: Second hand timber flooring 3Jan 27, 2009 12:37 pm Was the 80mm size the one you can secret nail? Sounds like what we need. I'll have to head down and see what you've got there. Cheers, Pete viewtopic.php?f=38&t=8824 Re: Second hand timber flooring 4Jan 27, 2009 6:30 pm 80mm and 108mm are secret nail profile.
There is also now an approved installation method for secret nailing 130mm boards. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4491 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37160 |
