Browse Forums Flooring & Floor Covering Re: Hallway Carpet Runners 4Jan 14, 2009 6:19 pm Firstly, I'd try the yellow pages for rug specialtists eg. http://www.mmrugs.com.au/pages/rugs/runners.php. I'm sure there are lots of others in Melbourne. Of course, you need to talk to them.
You can also take remnants to these kinds of businesses & have them joined & overlocked. Again, you'd have to suss out who would be prepared to do this. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51794 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61375 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
