Browse Forums Flooring & Floor Covering 1 Jan 13, 2009 5:09 pm I am leaning towards 600x600 polished porcelain tiles for the floor, but someone at work said b e carefull with these as the bigger the tile the more chance of them cracking if there is movement in the house, especially with the thinner grout lines.
Has anyone heard of this being more a possibility than with the smaller tiles? Know where your going in life............... you may already be there Re: Porcelain tiles cracking! 2Jan 13, 2009 11:52 pm We just put down heaps of 600 * 600 and our tiler didn't mention that as a problem. The only issue he mentioned with the larger tiles was the need for a perfectly flat surface, whereas you can get away with a bit of unevenness with smaller tiles. Re: Porcelain tiles cracking! 4Jan 15, 2009 12:18 pm Tiles that crack are from poor installation the floor needs to be prepared first by using a leveling compound if they do not do this than yes they can crack.
Craig Re: Porcelain tiles cracking! 5Jan 15, 2009 6:24 pm The grout is generally the weakest part of the floor so it will therefore crack before a tile will. With the larger format tiles you have less grout to crack so there is more chance of a tile cracking.
However, as noted in the other replies there are other important factors as well, proper preperation of the floor and flexible glue will greatly reduce any problems. If it is the 600x600 tiles you want get them, as we have come across many floors with 330x330 tiles with huge cracks right across the whole room. 1 6638 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7795 Our house was completed 8 years ago. Builder did not leave any spare roof tiles behind. Just found out that one tile is cracked. Wanted to replace the tile but most… 0 2785 |
