Browse Forums Flooring & Floor Covering Re: timber floor on concrete steps 2Jan 01, 2009 10:44 am You would just fix it in the same manner as the rest of the floor if using real timber flooring. I don't know if I would use a floating type floor on stairs. Following these simple steps will help you mitigate unwanted costs, have your expectations met and give… 0 4535 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15918 Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1551 |
