Browse Forums Flooring & Floor Covering 1 Feb 12, 2004 9:52 pm I want to tile my kitchen floor. Currently it is linoleum glued to OSB wood flooring.
All installations materials I read recommend putting down backerboard then the tile. My problem with this is it raises my floor up and the surrounding carpet and hardwood wouldn't match up with the new tile floor. Can you lay tile on wood subfloor? Re: Tile Flooring Installation 2May 28, 2004 3:56 am Mike I want to tile my kitchen floor. Currently it is linoleum glued to OSB wood flooring. All installations materials I read recommend putting down backerboard then the tile. My problem with this is it raises my floor up and the surrounding carpet and hardwood wouldn't match up with the new tile floor. Can you lay tile on wood subfloor? In a nutshell. Yes! 1st the wood floor must be sound( have no movement on it). If there is movement you must screw it to the joists. 2nd Apply a generous layer of PVA adhesive and allow to dry. 3rd Add and mix PVA adhesive to your tile adhesive and treat just as normal and the job will last many years Re: Tile Flooring Installation 3Sep 06, 2004 12:31 pm In deference to the previous reply - no you can't ( successfully).
1. Ensure your flooring is secure - renail any loose boards 2. Install a suitable underlay as per the manufactures recommendations. 3. Lay your tiles as per the adhesive manuf. instructions The join between the tiled area and the existing carpeted area is covered by a 'cover strip' usually available from your tile supplier. The difference in height (usually through door openings) is is taken up by the cover strip. In some situations, where for example thick slate flooring is used, a 't' piece edge strip is employed. In normal situations carpet allowance (including underlay) is close to the tiles plus undelay height. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Good day everyone, I have two queries regarding stacked stone style facade feature tile installation. 1. I am looking for an installation price guide to install stacked… 0 658 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5422 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6439 |
