Browse Forums Flooring & Floor Covering 1 Nov 14, 2008 9:46 am Hi All,
I've found this gold mine of information and would really appreciate some advice on my little problem. I'm in the process of doing a renovation and extension to the house and just ripped out the existing flooring (carpet and slate) and realised we've got Tassie Oak in most of the rooms except for one which has the yellow tongue floor board. The conditions varied as house was affected by termites a while back. I have decided to put solid timber flooring (80/19) throughout the house apart from the bathrooms and bedrooms. I've talked to a few installers/suppiers and some said I will need to put plywood down on the existing tas oak and some said not. Most of the installers I've talked to been out to see the job and they are giving me conflicting advices. Thanks, Re: To Ply or not to Ply 2Nov 14, 2008 6:06 pm You can lay over the existing T&G floor though you would lay the boards perpendicular to the old ones Re: To Ply or not to Ply 3Nov 17, 2008 2:39 pm Thanks Luke,
Another installer have just said it is not necessary to do so. He said it is because he will be using glueing the whole length of the boards and secret nailed at intervals. I don't want to spend more but would rather do it properly is this is needed. Cheers, Re: To Ply or not to Ply 4Nov 17, 2008 6:16 pm You better to glue over sheet flooring regardless, that way you won't have any creaking problems between the two surfaces. The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6178 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31282 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15276 |
