Browse Forums Flooring & Floor Covering Re: Formica Laminate Floorboards 4Nov 30, 2008 7:44 am If you choke a smurf... what colour do they turn? Re: Formica Laminate Floorboards 5Nov 30, 2008 9:42 am Do it right the first time and please dont shortcut the job Re: Formica Laminate Floorboards 6Nov 30, 2008 9:50 am Do it right the first time and please dont shortcut the job Re: Formica Laminate Floorboards 7Nov 30, 2008 9:53 am the reason for the pva glue as well is so that it blocks any moisture entering through the top and attacking the mdf causing it to swell.
also you will find that no matter the thickness of the floating floorboard they are stronger than the real wood floors and less prone to scratch and buffer marks. Do it right the first time and please dont shortcut the job Hi All New to the forum and looking for some advice, has anyone else renovated an old miners cottage in or around Ballarat and been able to identify the flooring? We… 0 8767 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 We are doing heaps of hybrid at the moment and the cost sits between $60-65/sqm including installation. Stairs are around $90-100 each 1 4310 |
