Browse Forums Flooring & Floor Covering 1 Nov 06, 2008 9:41 pm Hi,
Can anyone recommend a reputable person to lay and finish timber flooring in Perth? We have already purchased the flooring (blackbutt) to install over 70sq/m including 17 steps from memory. My email is mtesija@hotmail.com Re: Perth Timber Flooring installers 2Dec 01, 2008 6:11 pm BLT Flooring installed my floor and were recommended by a friend!
I have no complaints at all about the boards or the fitting job.. The guy that fitted it was Andy - 0416943959. They also had a website www.bltflooring.com.au Re: Perth Timber Flooring installers 3Dec 01, 2008 7:25 pm Hi Andrew,
were your boards prefinished or do you know if he finishes them off aswell for raw boards? I also need an installer in Perth for our jarrah floorboards but they are not prefinished so will need the sanding and finishing etc. thanks Re: Perth Timber Flooring installers 4Dec 01, 2008 7:40 pm the boards were pre-finished -don't think they sanded - not too sure.
i am sure they willput you intouch with someone though! Andrew Howey Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15840 Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8899 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6148 |
