Browse Forums Flooring & Floor Covering 1 Jun 18, 2024 8:01 am Hi I just finished building a backyard office pod, 2400 X 4000. The subfloor is yellow tounge and I am planning to direct stick 18mm engineered timber floorboards to the yellow tounge. I will be using bostik ultraset. I've been getting conflicting advice on this. Some say I can direct stick flooring over yellow tounges, others say I should not dot it. Can someone here please advise? Cheers Re: Engineered timber floor over yellow tounge 2Jun 18, 2024 11:43 am I have used direct stick 18 mm solid timber over yellow tongue, 20+ years on its perfect Make sure you sand yellow tongue to remove wax coating or it may not stick and make sure you have good sub floor ventilation if on ground level. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Hi Wokka, I would have to agree re "I would be taking this opportunity to replace your subfloor in the sections that… 2 13861 ![]() Hi Everyone One of my pet peeves about the construction industry is the quality of flooring installers as generally they are unlicensed and unregulated. In 2009 the… 0 13713 ![]() To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 11612 ![]() |
