Browse Forums Flooring & Floor Covering 1 Oct 29, 2023 1:03 pm Has anyone used XCEM Alphafloor concrete panels for subfloor and would recommend them over other subfloor options (Hebel Powerfloor, Plywood, particle board)? I would like to get an idea of supply and installation cost per sqm for XCEM Alpha flooring. Also, I want to know if Alphafloor panels considerably lower the noise (talking, music etc.) transmission between between floors on their own or I will need additional measures such as soundscreen (acoustic insulation)? Hebel 75mm floor: The glue added will do nothing, will not miraculously stick panel together. Often the panels get cracks in them from handling and if a joist is… 3 12047 1 6599 As above, you will need to trim your sheet to land on the joist, also make sure you are running your length at right angles to the joists 2 9161 |
