Browse Forums Flooring & Floor Covering 1 Feb 18, 2022 4:31 pm Hi all! Hoping to get some expert advice here. I want to remove the yellow tongue particleboard in my bathroom by cutting along the bottom plate all around. Would this be possible considering that there is no joist underneath the internal partition on the right hand side as can be seen in the attached photo. I’m assuming this wall isn’t load-bearing and so it’s be fine to do. Thank you Re: Bathroom subfloor removal 2Feb 18, 2022 4:40 pm [quote="GTales":1jw2fdfs]Hi all! Hoping to get some expert advice here. I want to remove the yellow tongue particleboard in my bathroom by cutting along the bottom plate all around. Would this be possible considering that there is no joist underneath the internal partition on the right hand side as can be seen in the attached photo. I’m assuming this wall isn’t load-bearing and so it’d be fine to do. Thank you[/quote:1jw2fdfs] [img:1jw2fdfs]https://forum.homeone.com.au/u/104904_1645166427.jpeg[/img:1jw2fdfs] Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4096 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 7653 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14320 |
