Browse Forums Flooring & Floor Covering 1 Feb 18, 2021 4:41 pm Has anyone done this before and does it look good? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We were hoping to turn our spotted gum timber flooring (picture above) into something more muted and neutral. Wasn't sure if just sanding + applying water based coating was enough. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Lime wash on spotted gum – thoughts? 2Feb 18, 2021 6:38 pm Just used loba easy finish WS with whitener added, will give you the finish you are after. This is on cypress with an oil based sealer. Using a loba sesler will give even better finish almost like raw sanded timber. Very good feel underfoot. My flooring guy recommended it over Bona. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Lime wash on spotted gum – thoughts? 3Feb 18, 2021 9:15 pm Pulse Just used loba easy finish WS with whitener added, will give you the finish you are after. This is on cypress with an oil based sealer. Using a loba sesler will give even better finish almost like raw sanded timber. Very good feel underfoot. My flooring guy recommended it over Bona. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Pulse! I've been recommended to use Loba 2K, is it different from easy finish WS? And how about Intergrain – can whitener be added to it too? Re: Lime wash on spotted gum – thoughts? 5May 18, 2021 11:55 pm It looks very nice indeed. I’ve come across something like this watching YouTube as I was interested to see how the brownish timber floor is sanded and stained to change its colour. I’m actually deciding between this approach and laminate flooring with similar colour at the moment but mainly due to its durability. How hard or tough is the top coating when sanding and polishing are completed - we have 2 small children. Hi We have Hybrid Spotted Gum Hp0995 from carpet call. It turned out to be very dark and rough. Is there any polish or product we can use to make it shinier ? 0 9182 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4697 2 462 |
