Browse Forums Flooring & Floor Covering 1 Nov 01, 2020 8:28 pm Hi all. I just had my timber floor bleached and coated. Colour looks nice but the texture is not smooth. It has many areas where I can feel the grain of the timber and also many areas that are very rough especially in areas where there are some kind of little bubbles as on picture. What are tgese bubbles/ raised dots? Is it normal? I was expecting a soft finish and can see that dirt is going to accumulate in that rough area making it very hardware to clean. Sander said he did not sand between coats. Apparently he put 3 water based coats with some white in it to make it look lighter. He said he did not sand between coats because he did not want to affect the colour. Is this right? I want to ask him to sand the floor on top of the 3rd coat and apply a 4th one but is this possible? Is it true it will affect the colour? I do not have time to end up with uneven colour and have to start the job all over again. Help pls! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Actually looking again I do see a difference. On mine the staircase runs higher than the skirting, which is even on both sides, whereas on yours the skirting is higher… 8 1794 ![]() They have now put the other strip of wood under the stairs. Looks terrible, I have asked for a straight edge. 4 1264 HI there, West trowel wall designs - 0448 794 393 or Lisa from Troweled Earth - 0449 902 250 - If you have instagram / facebook you can look up both to see examples of… 4 4769 |
