Browse Forums Flooring & Floor Covering Re: Carpet and underlay 2Oct 18, 2020 1:23 am We did our own carpet and underlay (mainly because I used to work at carpetcall so worked out a good deal) and got really plush carpet and upgraded underlay.. I honestly recommend it, you can really notice the difference and carpeted areas are usually used quite a lot. But that is just my opinion. Re: Carpet and underlay 3Oct 18, 2020 11:15 am ![]() We did our own carpet and underlay (mainly because I used to work at carpetcall so worked out a good deal) and got really plush carpet and upgraded underlay.. I honestly recommend it, you can really notice the difference and carpeted areas are usually used quite a lot. But that is just my opinion. Thanks but which to put more money on? Carpet or underlay? Re: Carpet and underlay 4Oct 18, 2020 8:26 pm ![]() ![]() We did our own carpet and underlay (mainly because I used to work at carpetcall so worked out a good deal) and got really plush carpet and upgraded underlay.. I honestly recommend it, you can really notice the difference and carpeted areas are usually used quite a lot. But that is just my opinion. Thanks but which to put more money on? Carpet or underlay? A mix of both IMO mate. Upgraded underlay has extra benefits such as better resistance to liquids (in some cases) etc. plus it is not overly much more. Best thing you can do is go to a store and get them to put carpet that you like on different underlays and walk on it barefoot (if they let you due to the current circumstances) this is a good way to get a good feel ![]() Re: Carpet and underlay 5Oct 18, 2020 8:27 pm ![]() ![]() ![]() We did our own carpet and underlay (mainly because I used to work at carpetcall so worked out a good deal) and got really plush carpet and upgraded underlay.. I honestly recommend it, you can really notice the difference and carpeted areas are usually used quite a lot. But that is just my opinion. Thanks but which to put more money on? Carpet or underlay? A mix of both IMO mate. Upgraded underlay has extra benefits such as better resistance to liquids (in some cases) etc. plus it is not overly much more. Best thing you can do is go to a store and get them to put carpet that you like on different underlays and walk on it barefoot (if they let you due to the current circumstances) this is a good way to get a good feel ![]() Thanks mate! Hi, I am getting turf underlay put into my backyard area... roughly 50sqm. It hal the area, i can fit about 100mm of underlay... but in other areas its deeper and i will… 0 664 No underlay would eliminate the noise they definitely reduce them. I have laminate(10mm) flooring with Dunlop Acoustic premium underlay done by CarpetCall in Sydney. If… 3 964 Hello Guys, This may have been posted many times, I read some posts but still couldn't get a straightforward answer. We are toggling between carpet and laminate flooring… 0 914 |
