Browse Forums Flooring & Floor Covering 1 Sep 15, 2020 1:27 pm Team, need some advice, just moved into a house where the precious owners have ripped the carpet and repalxes it with vinyl/floor board. I see a gap between the skirting and floorboard. Concerned about he dust and water accumulation. Any advise on what I can do to seal it ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help!Gap between skirting and floorboard 2Sep 15, 2020 2:45 pm viju_009 Any advise on what I can do to seal it ? Most would install quarter-round beading. It’s cheap and effective, but doesn’t look the best IMHO. The best looking, but most expensive solution, is to the lower the skirting boards. Re: Help!Gap between skirting and floorboard 3Sep 15, 2020 2:47 pm arcadelt viju_009 Any advise on what I can do to seal it ? Most would install quarter-round beading. It’s cheap and effective, but doesn’t look the best IMHO. The best looking, but most expensive solution, is to the lower the skirting boards. Does it mean removing the existing skirting boards and reattaching the same one or replacing them with new skirting boards ? Re: Help!Gap between skirting and floorboard 4Sep 15, 2020 3:20 pm viju_009 Does it mean removing the existing skirting boards and reattaching the same one or replacing them with new skirting boards ? You could do either. Both methods would require significant re-finishing of both the wall and the skirting board, although probably less for new. There is also a chance that you would break some of the old skirting boards as you try to remove them; however, even if you did break some, you could consolidate the old skirting into less important rooms, and save new skirting for more important ones. Re: Help!Gap between skirting and floorboard 5Sep 15, 2020 11:01 pm Run No More Gaps around it? We're planning to do that with ours where there's a gap (though maybe a bit smaller) between the skirting and our vinyl floorboards. Joe Apologies for the delay in getting back to you. If you haven't sorted this already you need to caulk this gap. Not sure where you are but if you are in Sydney I can… 5 4335 2 7482 4 6009 |
