Browse Forums Flooring & Floor Covering Re: Floating floors in wet areas plus timber floor questions 5Oct 12, 2011 5:10 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Floating floors in wet areas plus timber floor questions 7Oct 13, 2011 5:30 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Floating floors in wet areas plus timber floor questions 14Jun 24, 2012 8:06 am Great. No worries then ! Your local Harvey Notman was correct. If required, small ramps can be fitted under the carpet to assist, but you won't know if they are truly required until you choose your carpet and underlay. CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6655 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3330 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 1035 |
