Hi guys,
Just wanted to know what you guys did to cover your garage floor??
At the moment ours is just concrete.....
Browse Forums Flooring & Floor Covering Re: Garage floor covering 2Nov 05, 2011 9:53 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Garage floor covering 6Nov 06, 2011 8:46 am Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: Garage floor covering 13Dec 04, 2011 9:04 am Any one with experience with Cementaid? I'm am looking at applying diamite + rokite in the garage. Its aparently is a pentrating type concrete hardener and sealer respectively. Might be overkill but like the idea of toughening up the concrete surface by filling pores as opposed to coating it (I'm a grease monkey who likes to weld, hammer, drag engines across my floor). Re: Garage floor covering 15Dec 08, 2011 8:05 pm Any form of densifying the concrete will make it harder. Less subject to 'damage'... though fillers are not normally considered densifying. Densifiers normally would ingress the concrete substrate and capillary fill and with a chemical change and 'harden' the substrate. Thanks for the heads up theanonyuser . Where you are coming from is where you are going to... Re: Garage floor covering 16Dec 11, 2011 8:38 am onc_artisan, what products would you recommend? The Dymark sealer is around $200 so that seems like a reasonable price to me, or is there a better product I should consider using for the garage floor? Re: Garage floor covering 17Dec 13, 2011 1:42 am This is very expensive but it might be a once only application, well you would hope so $$$$ http://epoxysupplies.com.au/index.php?r ... uct_id=111 Re: Garage floor covering 18Dec 19, 2011 1:43 pm We regularly use Protect Cretes Moisture Fix or Densiproof, with Moisture Fix 1 being the easiest to apply. Protect Crete's proudcts use a Slightly different chemical as its a Collodial Silicate as opposed to the cheaper Sodium or Lithium densifiers. All Depends on your Budget, I always purchase the best I can afford & overkill has mostly worked for me... Re: Garage floor covering 20Jan 18, 2012 7:56 pm Hi NEWLYWEDS, We have a range called Allure Garage ! It's purpose made for garages and can handle all the water and oil spills etc that occur in a garage. It floats over the concrete and can go straight over the expansion gaps in the concrete. It comes in around 30 or so colours including steel, stones and woods. CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW got it. thanks. I was looking for word ' Adobe' and added filter. all good. 12 14804 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18238 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17561 |
