Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 982Feb 26, 2024 5:43 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 983Feb 26, 2024 5:29 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 984May 27, 2024 4:26 pm Hi Michelle. You answered some questions about flooring earlier this year, but now I'm getting down to the pointy end and would appreciate your input. Following my kitchen being reinstalled I decided just to get the loungeroom, kitchen and open living area re floored and the companies I've approached have given me different options. At the moment the existing flooring in the kitchen area and part of the open plan area was floating laminated timber with a foam pad laid over terracotta floor tiles. In the remainder of the flooring in the open area on top of the concrete slab the previous owners in 2003 put cement sheeting down then laid the floating floor. The floating floor in the kitchen and part of the open living area l have removed myself, that's how I've established what it there. I've been told by one company they can lay Masonite boards onto the slab to lift it to the level of the tiles, then lay the VPL over the top but this method would void warranty. The other company has advised that the terracotta tiles will have to be removed, the whole slab area ground, leveller applied then the VPL's laid. I'll be removing the skirting boards in the three areas so they can floor up to the walls as l need the floors to be reasonably watertight and l will reinstall the skirts and architraves myself. Can you advise me out of the two opinions I've been given which one is the preferable one? Cheers. Carmel Dwyer Re: I work in flooring - do you have a flooring question? 985May 27, 2024 6:09 pm Jaspersmum Hi Michelle. You answered some questions about flooring earlier this year, but now I'm getting down to the pointy end and would appreciate your input. Following my kitchen being reinstalled I decided just to get the loungeroom, kitchen and open living area re floored and the companies I've approached have given me different options. At the moment the existing flooring in the kitchen area and part of the open plan area was floating laminated timber with a foam pad laid over terracotta floor tiles. In the remainder of the flooring in the open area on top of the concrete slab the previous owners in 2003 put cement sheeting down then laid the floating floor. The floating floor in the kitchen and part of the open living area l have removed myself, that's how I've established what it there. I've been told by one company they can lay Masonite boards onto the slab to lift it to the level of the tiles, then lay the VPL over the top but this method would void warranty. The other company has advised that the terracotta tiles will have to be removed, the whole slab area ground, leveller applied then the VPL's laid. I'll be removing the skirting boards in the three areas so they can floor up to the walls as l need the floors to be reasonably watertight and l will reinstall the skirts and architraves myself. Can you advise me out of the two opinions I've been given which one is the preferable one? Cheers. Carmel Dwyer Hi Carmel, can you tell me what vinyl floor you're getting quotes on please. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 986May 27, 2024 9:39 pm Hi Michelle The two hybrid options I've been given as follows: 1. Terra Mater Eternity Range. Spotted Gum. Type: Hybrid/Rigid Core. Wear Layer 0.5mm. Composition: Virgin PVC/Stone. Integrated high density underlay. 2. Castleton Range. Spotted Gum. Type: Hybrid/SPC Core. Wear Layer 0.55mm. Composition: SPC. Base: 1mm High Density Foam Dunlop underlay. Hope this makes sense to you. Cheers. Carmel Re: I work in flooring - do you have a flooring question? 987May 28, 2024 6:33 am Jaspersmum Hi Michelle The two hybrid options I've been given as follows: 1. Terra Mater Eternity Range. Spotted Gum. Type: Hybrid/Rigid Core. Wear Layer 0.5mm. Composition: Virgin PVC/Stone. Integrated high density underlay. 2. Castleton Range. Spotted Gum. Type: Hybrid/SPC Core. Wear Layer 0.55mm. Composition: SPC. Base: 1mm High Density Foam Dunlop underlay. Hope this makes sense to you. Cheers. Carmel Hi Carmel, I've been told by one company they can lay Masonite boards onto the slab to lift it to the level of the tiles, then lay the VPL over the top but this method would void warranty. - This is correct. BUT, I would ring the manufacture and check on that voiding of warranty! I can't see how that would void. The other company has advised that the terracotta tiles will have to be removed, the whole slab area ground, leveller applied then the VPL's laid. - This in my opinion is the best way to approach a floor. Start new. BUT the hybrids have been designed to go OVER tiles. So this one is confusing as well. Ring both manufactures and ask these questions. Best to hear it from them. Good luck Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 42305 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 11304 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 5238 |
