Browse Forums Flooring & Floor Covering Re: Bathroom Tiles 4Jan 18, 2022 2:11 pm Spazzen I actually prefer the floor tile you're resting the samples on as the wall tile over the white. Otherwise I like the rest of it. That tile is actually the floor tile. The smaller square one is the same tile only in semi-gloss. My plan was to do a feature wall - bath / window wall in the semi-gloss version of the floor tile. The rest of the walls will be in the off-white. I could also do the feature wall in the same matt floor version - I just figured as the off-white is gloss, I should also choose gloss for the feature wall. I originally looked at doing the whole room in the same tile but I thought it made our small bathroom look too dark and claustrophobic. Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6064 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8370 Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10375 |
