Browse Forums Flooring & Floor Covering Wet floor 2Nov 26, 2021 2:04 pm If the floor is sealed, it shouldn’t be an issue for the floor itself, but perhaps a slip hazard for the occupants…so be careful. Also, just because it happened once doesn’t mean it will happen every time, but it also doesn’t mean it won’t happen again. All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3663 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16559 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
