Browse Forums Soft Furnishings 1 Dec 19, 2013 4:53 pm So I bought these bar stools second hand and want to put a cushion on and cover. How would you do it? I have bought material and cushions (foam). Do I lay foam all the way across curve or do I do main part of seat and then another piece for the back? Do I cover just the cushion and put it on or pull all way under? Proving harder to work with the curve than I thought. See pics- curve is probably 8cm high. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sent from my GT-I9505 using Xparent Purple Tapatalk 2 Re: Upholstering a bar stool, HELP PLEASE! 2Dec 19, 2013 6:01 pm I'd cut the foam to the same size as the stool tops including the sloped areas and cover the foam as a standard cushion. To fix it to the stool I would sew on extra fabric to the back so it basically slides on like a sock on the back sloped section. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Upholstering a bar stool, HELP PLEASE! 3Dec 19, 2013 6:52 pm Thanks for your reply. I'm a bit of a novice at this. I can sew though. Made costumes for years. I would need about 1/2 inch to inch in height so how would I accommodate for this at the top of chair. I can't just sew it like a pillow case as seam will sit funny. I'm almost going to need to do another strip attached to top piece to give it depth iykwim Please suggest a solid quality swivel bar towel holder in bathrooms & bedrooms from… 0 3213 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7444 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12980 |
