Browse Forums Buying Land Re: Flat sandy building block-developer dumped building rubb 2Feb 01, 2020 2:29 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Flat sandy building block-developer dumped building rubb 4Feb 01, 2020 4:40 pm It will just be left over from the site clean. When the original subdivision was done part of the requirements is to clear the block of all existing building and infrastructure. Typically that is done with an excavator with a slotted bucket so anything bigger than 50mm is removed from site. They rake the site. It's not a perfect science though and sometimes bits will get missed. As long as it was completed and the old leach drains and septic system has been removed and filled in. You will soon tell if the leach drains are still intact as they will still be in place and it won't just be odd bits of concrete that at one time formed it. I know our block had the odd brick here and there. It's pretty standard on a subdivided block or an KDR. Your builder isn't going to charge you extra for hard digging and realistically the odd bit of brick or concrete on the building envelope isn't the end of the world. It's organic matter that's a big issue as it will break down over time that can cause issues with movement below the slab. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4123 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13905 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7222 |
