Browse Forums Buying Land 1 Sep 23, 2019 5:16 pm Hi All, I’m in the process of buying a land and have been getting different answers from builders and estates in regards to defining a zero lot land. Does anyone know what defines a zero lot land? Is this identified on the land? I’m told if there is an easement on one side, this means it’s a zero lot? Many thanks. Re: How to Identify a ‘zero lot’ land 2Sep 23, 2019 5:48 pm Zero lot simply means the actual building is built to the very edge of the lot. There is effectively zero amount of the house lot past the edge of the build. (In actual fact the build is usually 20-30mm off the real boundary) This is often employed at the side of garages. If you have an easement then you can never have a zero lot build on that side as the house can only be built up to the edge of the easement leaving space to the boundary lot. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How to Identify a ‘zero lot’ land 3Sep 23, 2019 5:54 pm chippy Zero lot simply means the actual building is built to the very edge of the lot. There is effectively zero amount of the house lot past the edge of the build. (In actual fact the build is usually 20-30mm off the real boundary) This is often employed at the side of garages. If you have an easement then you can never have a zero lot build on that side as the house can only be built up to the edge of the easement leaving space to the boundary lot. Thanks chippy. Would it typically stipulate in the contract if you can build to the very edge of the lot? Re: How to Identify a ‘zero lot’ land 4Sep 23, 2019 6:03 pm If it's just a standard residential block then any requirements around building too zero lot would be handled during planning. If the land is in a development then there may be certain covenants that stipulate what you can and can't build. I've only ever purchased and built on standard residential blocks so building zero lot has only ever been about meeting residential design codes. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4906 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10201 1 429 |
