Browse Forums Buying Land 1 Jun 01, 2019 10:28 pm Hello there, Good day. I was interested in a land and signed a contract with due diligence clause. Found today that there is an easement on the property but it was not disclosed in the contract by the agent or the seller. They have selected encumbrances as NO - which to my understanding is incorrect as there is an easement. Does this constitute to breach in contract ? Please clarify I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5148 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17138 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16130 |
