Browse Forums Buying Land 1 May 13, 2019 12:39 pm Hi Guys, I am here to ask about the site cut cost. I have land with slope fall from back to the front of 3.22m with the depth of 27m on one side and 47m on the other. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have been talking to custom builders and the house build project is getting well over my budget. I feel; if I do the site cut my self for the entire site and have retention wall will a lot cheaper. What you guys reckon, If I do the site cut myself - will the bulk builders build a home on land that is already site cut? How much would it cost me to cut a 611sqm land with retaining walls? Just a ballpark figure to get an idea. I would appreciate if someone can recommend me a guy who is good and reasonably priced for this task. Also, if I build a house on stumps, will the cost go down too much? Re: Slope Land Site Cut - VIC 3Apr 05, 2020 10:26 am We have a 38M long block with a 3M (diagonal) fall, builder has quoted $80K for site prep on the cut & fill, with retaining walls around a lot of it! https://forum.homeone.com.au/viewtopic.php?f=31&t=98372&p=1867245#p1867245 You could cut and fill yourself, as long as you follow what the builder requires in space, levels and retaining walls to the required standard. If they have a level plot to work on, it should work out a lot less expenses for you! To do stumps, you would need to know the soil type and what's underground, as this may affect how deep the stumps need to go! A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223474 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24830 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 1752 |
