Browse Forums Buying Land 1 Apr 29, 2019 9:54 pm Hello there, We are looking at a potential suburb, but the land have overland flow area at the back of the property. The seller and real estate agent are promising it is only at the back and no special construction is required . How can we be sure about it and is there any special building construction required for overland flow area? Will that greatly increase the build cost. Also in the land contract what clause should I add to protect myself if construction is going to be costly? Please suggest Cheers Ganu Re: Buying overland flow land 2Apr 30, 2019 12:00 pm How big is the lot? If the overland flow area is hundreds of mt. from your constructed house..then may not be an issue. Otherwise why risk your $ on potential hazard zone? Your insurances will be higher too. Re: Buying overland flow land 3Jun 01, 2019 3:39 pm Hello Ganu, Did you find out more info on the overland flow? We are currently looking at a property which has overland flow area. Just saw below on council web site https://www.brisbane.qld.gov.au/plannin ... ssessments Cheers Chekan Re: Buying overland flow land 4Jun 01, 2019 8:10 pm There are particular prescribed acceptable development thresholds and triggers for code assessment depending on the type and extent of flooding. If you send me the address and a brief summary of what you want to do I can let you know if you'll need a DA. rhett.b@dtsqld.com.au Follow Our Clarendon - Double Gable, Hamptons Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 Re: Buying overland flow land 5Jun 01, 2019 10:18 pm Chekan Hello Ganu, Did you find out more info on the overland flow? We are currently looking at a property which has overland flow area. Just saw below on council web site https://www.brisbane.qld.gov.au/plannin ... ssessments Cheers Chekan Hello Chekan, Yes, we called council and found out that there is an Easement agreement arrived between the seller and the Council on what can be done in the overland flow area - basically no structures are allowed. But call council or in the title search find out what is allowed in regards to Fence, Building, Structures, Vegetation, etc... Re: Buying overland flow land 6Jun 01, 2019 10:25 pm Rhetti There are particular prescribed acceptable development thresholds and triggers for code assessment depending on the type and extent of flooding. If you send me the address and a brief summary of what you want to do I can let you know if you'll need a DA. rhett.b@dtsqld.com.au Thanks Rhetti - have send you a PM You may still have a case, but your next step is to speak to a lawyer. 3 1646 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6985 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6445 |
