the above, is the newly released land in Fig Tree Pocket, QLD. which block you believe would be the best to buy? why?
Browse Forums Buying Land Re: which block of land would be better to buy? 2Mar 05, 2019 11:05 am Contours? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: which block of land would be better to buy? 7Mar 05, 2019 3:45 pm Have you chosen an home to build? This will also be a deciding factor. Do you prefer a wide frontage - blocks 13 & 14. I think before you put on any offers, do your research on floor plans you like to find out what minimum block width & depth those houses need. Good luck! Re: which block of land would be better to buy? 9Mar 05, 2019 7:24 pm I also think #14 would be good with dual crossovers for possibly rear shed and front garage. Rear living could be north, although width might be tight? I actually think #16 or #24 might be worth considering due to their 'east/west' orientation. Mostly because you can have your main living areas on the long north aspect, especially with no major obstructions to your north (apart from the existing property, but single story?....if so 5-6m clearance to your building would be plenty). Also #17 isn't too bad either for similar reasons to above. So yeah maybe look at those East-West blocks, and if you can get the front facing west even better....use your garage for sun protection! --------------------------------------------------------------------- Check our Homeone build blog here brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7588 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1492 |
