Browse Forums Buying Land 1 Jun 02, 2018 5:04 pm We have an easement on the back of our land for storm water. Has anyone had experience or know what the rules are around raising the land on top of this easement? We have a sloping backyard so wanted to lift it as much as possible to even everything off. There is also a storm water drain that would need raising so just after anyone’s suggestions. We are in the Blacktown council. Thanks! Re: Raising land on top of easement 2Jun 02, 2018 10:30 pm One problem in raising the land is any foundations for a retaining wall may interfere with the pipeline in the easement. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Raising land on top of easement 4Jun 02, 2018 10:44 pm abdm14 Would this need to be approved by council? I would check The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17113 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16127 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3322 |
