NBN pit & pipe
We’ve asked for a conduit in by our builders as we both work from home and definitely need Internet but I didn’t think all new builds get NBN links by default, I know businesses don’t but residential might be different.
Fairly sure all new blocks in aus need an nbn connection now. Telstra don’t run copper into new homes anymore like the old days. Ask builder what nbn are putting in maybe you’ll get an option for fibre?
Thanks I didn't realise telstra no longer run in copper, that explains why we need to put this in and the older homes on the street can just use their existing cabling!
Is it specifically a lead in for NBN service or is it just a general conduit/pipe for future services like voice and data?
Its specifically a lead in for NBN not just a conduit. They dont get the NBN until is available in the area but the house would be wired to recieve it as soon as its available. BTW big fan of your screen name, love the IT Crowd
I’m assuming then that the lead in cost is charged to you?
The IT crowd is great, as is Jen 👍🏼
Thank you, I didn’t realise all new homes get NBN lead ins, it makes sense though considering the roll out.
Yes telstra said it is legally the developers responsibility but if they dont put it in then the responsibility falls on the purchaser of the land 😠 Very annoying they are not following up on there own legislation. Fortunately we haven't settled on our land yet so we have a bit of power.
Developer needs to do the AFR (application for reticulation), it is required by federal law but the issue is no agency enforces it. It should be a requirement before titles are issued, but the various government departments have been slow to act & amend approval process. Go back to developer with the information in link below & hopefully they will comply. if they don't you have two options seek legal advice or form a body corporate with other owners of development to complete the AFR. I'm having this issue now myself, basically getting no responses from seller ATM. I gather they know this policy is not enforced & hopes I will eventually stop bothering him, I will most likely seek legal advice if I get no results with real estate agent.
https://www.telstra.com.au/smart-community#
Thanks, I found this link really helpful as it quotes the legislation and was written by a lawyer that specialises in telecommunications. Hope it helps you with your battle too.
https://www.google.com.au/amp/s/amp.the ... velopments
2
Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished…
19/05/2023
3
yep sounds good make the footing bigger to to allow for the pipe in the middle
23/07/2023
3
Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know.
