Browse Forums Buying Land Re: House orientation 2Jan 20, 2016 3:51 pm How big is your block? to you have room to position however you want? If it was me and you were space constrained I would flip the house from how it is in the picture. So that you could get good passive heating in winter from the northern winter sun. Our Build Thread - JG king Memphis Re: House orientation 3Jan 20, 2016 4:00 pm I agree with surtees if it is possible, mirror the floorplan. We were in the same situation ourselves when we were buying land and it was an estate requirement to have living areas on the north side of the house for solar gain in winter. Re: House orientation 5Jan 20, 2016 5:21 pm I like it. Not sure how you had it on the block before you flipped it but to me this way you get the alfresco and living on to the side of the yard you will mostly use Re: House orientation 7Jan 20, 2016 10:15 pm Looking at it flipped is good for the north sun and also I think it sits better to access you yard like kait-e said. Our Build Thread - JG king Memphis Re: House orientation 9Jan 21, 2016 2:36 pm What part of the country are you building in? The climate affects how much emphasis there should be on heating vs cooling. Then the direction of prevailing breezes can be relevant if you want to optimise for cross-ventilation. Also, what is the direction of North on the block of land with the updated plan? North-facing living space is good for winter, however North-West facing windows are a big heat liability in summer, so there could be a trade-off there, and it depends on just what that angle to North is. I'm also noticing that 4m setback to the front. One thing you may want to check is if there'll be room to park a car on the driveway in front of the garage door, because it can be handy to be able to do that. Re: House orientation 10Jan 21, 2016 2:48 pm Hi Reco, Your lot shape and the North direction is identical to mine. I've place the garage to the left side and extend it by another 2 meters. Hi, This is my first post. We are planning to buy new home via House and Land (H&L) Package around Boxhill/Gables/Marsden Park in Syndey. Googled reviews for most of… 0 10444 Very good points. Thanks so much ponzutwo for your advice. Appreciate it. 2 10326 Hi all, Trying to workout the minimum stepdown required between slab for my house and the outdoor alfresco area. Garage is 100mm lower than rest of the house and plan was… 0 3649 |
