Browse Forums Buying Land 1 Jan 22, 2013 12:42 pm Hi guys, need some advise about our block of land from a new estate, our initial searches on the land has flagged some overflow water paths on the parent lot of property, should that be of any concern since our proposed lot is quite further down compared with other lots higher up. Our lot is about 40m as per the big lot plan, whereas the highest is about 55m.. any advice is appreciated ! Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6181 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9530 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13735 |
