Browse Forums Buying Land 1 Oct 18, 2011 7:42 am Where can I find info on houses to build on piers or how to get a block approved to slab build when coumcil says I must raise floor height 600mm above current height due to water considerations? I can't seem to find many builders out there in the Hunter region NSW, was going to build a Coral Noosa 29. I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12130 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7231 |
