Browse Forums Buying Land 1 Jun 20, 2011 1:47 pm When we initially looked into buying our block, we were sent info which stated "..once you step up onto the land itself, the block has only a gentle slope of only 80cm approx over the entire block." We put down a $10k deposit and it is due to settle in just over a week. However, when the site tests were done (by the builder), we were advised that it was "double what we initially thought". When questioned, we were told a 3m slope. Do we have a case for false advertising as this obviously changes all our initial plans. Or will the buck be passed back to us that we should have had an independant survey done? We went ahead with the purchase as it is in the suburb that we wanted to build, and was advertised as "..actually one of the flattest blocks you will see in the estate." I don't classify a 3m slope as flat! All opinions greatly appreciated Re: False Advertising????? PLEASE HELP! 2Jun 20, 2011 1:55 pm What does the contours part of your land contract say? 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: False Advertising????? PLEASE HELP! 3Jun 20, 2011 1:58 pm The contours may have changed when they developed the land if the road wasn't in when you initially saw the block. This happened to some blocks near me, once the road went in the land changed considerably and the developer ended up cutting their sites for them as compensation after a bit of a battle. As stated above, it is important to know what is in your land contract. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: False Advertising????? PLEASE HELP! 4Jun 20, 2011 2:41 pm Err, what are "contours" referring to (gosh I really sound like I know nothing!)? There were only 2 blocks left in the court when we saw this one (ours & 1 other); all the rest of the houses were already under construction. The only thing not built is the footpath, so I presume the subdivision report measurements are exactly what we looked at "in the flesh"? Re: False Advertising????? PLEASE HELP! 5Jun 20, 2011 2:53 pm Contours show the slope. In the land contract there should be a drawing of the block with lines across it (on ours each line represented 20cm from memory) showing how the land alters in height. If it was as it is now when you bought it, I'm not sure you have too much recourse though. I'm unsure on the legalities of it if the land was developed when it was bought. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: False Advertising????? PLEASE HELP! 6Jun 20, 2011 3:09 pm In our land contract there is only a plan of subdivision. We got a copy of the survey report form the builder which shows the "contours", but only after the fact. So now we're stuck, or lose our deposit & go to court with the vendor Re: False Advertising????? PLEASE HELP! 7Jun 21, 2011 12:43 pm joles Contours show the slope. In the land contract there should be a drawing of the block with lines across it (on ours each line represented 20cm from memory) showing how the land alters in height. If it was as it is now when you bought it, I'm not sure you have too much recourse though. I'm unsure on the legalities of it if the land was developed when it was bought. This 1+ When we bought our block we received 'Contract Plans' with a provision about allowable differences in gradient etc, once the 'As Contructed' plans were provided. From memory the developer had a pretty big leeway in what they proposed, and what they actually had to deliver. We were fortunate that the 'As Constructed' plans did not differ significantly,we didn't encounter any issues. I guess that outlines the importance of having a solicitor review any contract that you sign to explain to you what potential problems you might encounter. That being said - I doubt the developer would have even sold you the land if you requested a clause that the land was subject to an independent survey. Cheers atom_ute Re: False Advertising????? PLEASE HELP! 8Jun 21, 2011 8:10 pm The original land contract should have the Contours in it.. When you paid your 10k and signed the contract it would have been in it. Pm me if you have these i can read them for you if you want. Mark Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7596 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 13220 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8428 |
