Browse Forums Buying Land Re: New house on an old slab 2Feb 16, 2021 8:25 pm Provide the slab isn't damaged during demolition, and it can be certified as fit for purpose. (OT...We've built on top of old basements.) You will need to have the existing Slab and footing details and an engineer will need to sign off. Single storey house is around $15K to demolish hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New house on an old slab 3Feb 16, 2021 10:23 pm StructuralBIMGuy Provide the slab isn't damaged during demolition, and it can be certified as fit for purpose. (OT...We've built on top of old basements.) You will need to have the existing Slab and footing details and an engineer will need to sign off. Single storey house is around $15K to demolish hth Thanks mate. Do you also know the cheapest way to build walls? I'm too confused between 3 options; 1) ICF/zego walls 2) corrugated iron/colorbond cladding 3) ACC panels. Option 1 doesn't need wooden/steel structure, but needs rendering/resealing/painting. Tradies come up with funny qoutes (considering I know nothing). Got qoute for zego blocks, just blocks cost $35/m2. Not sure how much would filling up mesh cost? Option 2 sounds cheapest and quickest, even most durable. I've seen in Northern Territory, where corrugated iron has been used in almost all buildings that could stand big heavy cyclones. But then it needs timber/steel frame and gypsum boards for interior walls. Option 3 again needs timber/steel frame and ACC panels need rendering or sealing and then painting. ACC panels cost only $0.80/m2 but the qoute of installing them was $100/m2. Please advise me which one to go for. And also please advise which method is cheapest or mix and match of these options can also work? Re: New house on an old slab 4Feb 17, 2021 8:24 am These days labour is the big ticket item, in Perth you wouldn't consider anything other than brickwork hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs 13 6564 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8049 Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 19175 |
