Browse Forums Buying Land Re: Cloverlea Estate - Chirnside Park VIC 1405May 27, 2014 8:49 am Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Cloverlea Estate - Chirnside Park VIC 1411May 27, 2014 10:45 am Yeah I'm a bit interested in the fencing situation as well. My main worry is the front fence. My Mrs only condition in living in any house is to have a white pickett fence out the front. So not sure what I'll do. Hopefully I can make a lower fence like feature set off the front boundary that isnt classed as a fence but makes the boss happy!! Re: Cloverlea Estate - Chirnside Park VIC 1412May 27, 2014 11:23 am I thought his might be handy to post for people building. It basically outlines what you need/don't need a permit for when it comes to retaining walls, verandahs, pools etc, basically the things you will do after you have built. We may need to put in a side retaining wall on our block so found this useful http://www.yarraranges.vic.gov.au/files ... Permit.pdf Re: Cloverlea Estate - Chirnside Park VIC 1414May 27, 2014 11:41 am I read the PDF that ftdt7882 linked to (thanks heaps!) and it says "Construction of a fence (other than brick or masonry) within 3m of the title boundary of a street and 1.5m high or less".... no permit needed. Which would suggest to me that if the fence is less than 1.5m and made of wood, that you can go put a fence anywhere you like out the front. This might be why you see the fence already constructed up the west end by stage 2 has an angled section down to the road? Re: Cloverlea Estate - Chirnside Park VIC 1415May 27, 2014 11:51 am The conditions in the MCP are in addition to those that are covered in the planning scheme are are particular to the estate. An example is 9.10(b) of the document states that Uncoated galvanised or zincalume steel sheeting must not be used on the Land under any circumstances. The council does not care about the fact you have used zinc sheeting etc to build something, however the MCP document will not allow such items to occur on the land. Even though council may or may not require that you get a permit for something, if it's stipulated in the MCP It overrides it. Re: Cloverlea Estate - Chirnside Park VIC 1416May 27, 2014 12:00 pm mutski I read the PDF that ftdt7882 linked to (thanks heaps!) and it says "Construction of a fence (other than brick or masonry) within 3m of the title boundary of a street and 1.5m high or less".... no permit needed. Which would suggest to me that if the fence is less than 1.5m and made of wood, that you can go put a fence anywhere you like out the front. This might be why you see the fence already constructed up the west end by stage 2 has an angled section down to the road? You are correct. But I assume that the signed contract with the Memorandum of Common Provisions (MCP) would form part of the council requirements for the estate? I don't know what overrides what though... I'd just hate to pay for my share of a fence on both sides and then find out I need to rip 5-6m of it down to comply with council/MCP. Re: Cloverlea Estate - Chirnside Park VIC 1418May 27, 2014 7:33 pm Xile, your PD sign is up woohoo! Has anyone seen my taps anywhere??? Their purple and gold They have a handle thingy on top that you turn, ???? If any one sees them can you tell them to go home block 1088 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 7015 I have posted this before: We hired Darbecca to do every stage inspection, and I strongly recommend them to anyone that asks me. They were amazing. Thorough reports… 2 5273 |
