Browse Forums Pools & Spas 1 Jul 21, 2020 8:44 pm We built our house two years ago, we have a narrow backyard and in anticipation for a pool we paid the building company to put footings under the house so we could get a pool closer to the house. We now have the funds to put in the pool but the pool builder is saying the footings aren’t deep enough. The pool is 3x6 with a depth of 1.1-1.8m. Looking at the picture are The footings deep enough for a pool this size? And would I be able to have the pool less than 1m away from the house??? I’m in WA THANK YOU 🙂 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Footings/piling under house for pool not deep enough???? 2Jul 21, 2020 8:51 pm If your block is sand defiantly not deep enough . If pool is concrete not deep enough . If pool is fibreglass and the side walls taper in at at 280mm or more it should be ok Cheers Re: Footings/piling under house for pool not deep enough???? 3Jul 21, 2020 8:56 pm wheeliworks If your block is sand defiantly not deep enough . If pool is concrete not deep enough . If pool is fibreglass and the side walls taper in at at 280mm or more it should be ok Cheers Thank you, yes the pool is on a sandy block. Was looking at fibreglass originally but now possibly going for a brick/concrete/liner pool. How deep would you suggest it should be? Re: Footings/piling under house for pool not deep enough???? 4Jul 21, 2020 9:31 pm Deep end would need to be 1250mm deep There are a few different options but you would be best to consult a engineer . Re: Footings/piling under house for pool not deep enough???? 5Jul 21, 2020 11:01 pm wheeliworks Deep end would need to be 1250mm deep There are a few different options but you would be best to consult a engineer . Thank you! As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 575 Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5563 Yeah my reasoning is just that those house posts are designed for vertical load not lateral. I just didnt want to risk interfering with the existing house… 4 11558 |
