Browse Forums Pools & Spas Re: Footings/piling under house for pool not deep enough???? 5Jul 21, 2020 11:01 pm wheeliworks Deep end would need to be 1250mm deep There are a few different options but you would be best to consult a engineer . Thank you! As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 572 Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5381 Yeah my reasoning is just that those house posts are designed for vertical load not lateral. I just didnt want to risk interfering with the existing house… 4 11551 |
