Browse Forums Pools & Spas 1 Feb 20, 2020 8:01 pm Hi I am in the process of buying a house and need to consider if a pool will fit. The property backs onto a canal / waterway (on the Gold Coast). The space is 7.5m wide and 7m deep from the patio to the revetment wall. How close to a revetment wall can a pool be? In addition how close to a neighbouring wall / fence can a pool be? Thank you in advance. Re: Pool near a revetment wall 2Apr 10, 2020 6:48 am In queensland we have two triggers for revetment walls. 1. A town planning trigger (only in some councils) - where structures are required to submit plans show structural impact on the wall, drainage etc and (sometimes) amenity impacts of the structure for other residents on the canal. 2. A building trigger - where the certifier issues a building approval and is required to supervise the works through to completion. So, talk to your local town planner first and ask if there are any triggers for building work within proximity to the revetment wall. Then, talk to a certifier and ask the same thing. Good luck Follow Our Clarendon - Double Gable, Hamptons Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 Re: Pool near a revetment wall 4Nov 18, 2020 6:08 pm NWTassie Hi I am in the process of buying a house and need to consider if a pool will fit. The property backs onto a canal / waterway (on the Gold Coast). The space is 7.5m wide and 7m deep from the patio to the revetment wall. How close to a revetment wall can a pool be? In addition how close to a neighbouring wall / fence can a pool be? Thank you in advance. Hi, If you are looking for Pool Excavation in Geelong we offer a vast range of services from industrial scale site cuts to suburban drilling and earthmoving. Pro Excavation Geelong is a local Excavation Contractors in Geelong. We used some earth-moving equipment in the construction industry like Excavators, Backhoe Loaders, Bulldozers Etc. Call us today for more information! Visit us at https://www.proexcavationsgeelong.com/ Pro Excavations Geelong Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9472 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5189 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11759 |
