Browse Forums Pools & Spas 1 Feb 16, 2020 12:26 pm Re: Vertical wood fence no rails- how to build? 2Feb 16, 2020 2:06 pm I would be using rapid set concrete. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Vertical wood fence no rails- how to build? 3Feb 16, 2020 7:23 pm Dig a deep strip footing for the fence, treat the timber where it will be inground with a bitumen membrane, build the fence and stand it up with temporary ties and bracing. Then simply backfill her with concrete, job done. I'd want the timber in at least 500mm concrete footing. Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Vertical wood fence no rails- how to build? 4Feb 16, 2020 7:30 pm What is it for? If it's pool barrier speak to an engineer first, as there won't be a compliant ore built design available. I would guess at foundation depth of min 1100mm depending on materials chosen (again, just a guess) Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3850 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15309 |
