Browse Forums Pools & Spas Re: Issues with robot pool cleaner 5Feb 03, 2020 11:57 am markrich1976 Would I only know that if i put it in for a service and they could have a look. Was just wondering if it would be worth it or better off buying a new one Just observe it in action. Note what it is doing. If it's only turning one way then it's likely something is jammed in one side or there's more wear on a component on one side. You can then assess if you can readily get parts and if it's a DIY job. Re: Issues with robot pool cleaner 6Apr 23, 2020 5:34 am This is very strange... maybe you have to turn it to the other side to make it clear the other side? Watch some videos also, maybe there are people who had the same problem with that cleaner. If you can't find anything on the net, better to contact the manufacturer. I am looking at building a house. Has anyone used Construkt Homes (based in Adelaide)? Does anyone have experience with this builder? 0 6451 12 5334 Industry type domestic contracts are prepared by industry bodies for the benefit of the builders. This means that if you are the owner watch out. One of the points is… 0 3235 |
