Browse Forums Pools & Spas 1 Oct 17, 2019 9:30 am I have a finished level of RL50.3 for my alfresco and RL50.1 for my pool which is accessed via Alfresco. I have an option to keep pool area and alfresco at same level as opposed to a 200mm drop on entry from alfresco to pool . Is it worthwhile doing this and what are the potential concerns e.g drainage or anything else ? Re: Finished level for pool and alfresco 2Oct 26, 2019 7:38 am I’m in the same boat. I’ve opted for. 200mm step down into the pool area. Purely as I don’t want water coming into the alfresco when I have a dozen people in the pool. I’m now thinking 200mm is probably too much and may change to 100mm. Somewhat similar to the threshold step coming into my house. Re: Finished level for pool and alfresco 3Oct 26, 2019 10:08 am KamadoJusto I’m in the same boat. I’ve opted for. 200mm step down into the pool area. Purely as I don’t want water coming into the alfresco when I have a dozen people in the pool. I’m now thinking 200mm is probably too much and may change to 100mm. Somewhat similar to the threshold step coming into my house. HI - I opted for all at the same level in the end as my alfreso is protected by a fence and to save the house I just added in a water stop...On some sides I have an overflow to a lower ground level Worked out ok in the end. Now the size of the pool room..? interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 39134 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 7180 Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 1978 |
