Browse Forums Pools & Spas 1 Oct 17, 2019 1:49 am Hello, I am looking to fit a 1200mm high concrete above ground pool with the goal of avoiding a pool fence. My question is, if there is an adjoining deck which is 400mm above ground level, how close can the decking get to the pool side? Ideally it would be as close as possible to give the feel that the pool is only 800mm high but still meet building codes. thanks, Ryan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Above ground pool regs 2Oct 17, 2019 8:30 pm If your in Nsw pool wall isn’t a barrier .in any other state you need 900mm from edge of poo to edge of deck . Remember fencing around entry point Re: Above ground pool regs 3Oct 17, 2019 8:49 pm wheeliworks If your in Nsw pool wall isn’t a barrier .in any other state you need 900mm from edge of poo to edge of deck . Remember fencing around entry point Great thanks for the information. So just to confirm, in South Australia, the attached image should comply as the edge to edge measurement is >900mm? The pool steps on opposite side will have a compliant gate and side barriers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ryan Re: Above ground pool regs 4Oct 17, 2019 8:59 pm That plan should be fine . Best to run it past someone at local council or a Certifier first Re: Above ground pool regs 5Oct 31, 2019 3:18 pm I’d follow the regs for qld... soon enough SA will catch up on the regulations and adapt the same rules... which means you’ll have to spend more in the future to rectify it. Re: Above ground pool regs 6Oct 31, 2019 3:22 pm That means there will be an “additional clear area” 1200mm from the top of your pool fence and arc 900mm out, to which your decking will conflict, as it’ll reduced your overall fence height. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11886 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13740 |
