Browse Forums Pools & Spas 1 Sep 24, 2019 1:01 pm G'day, I need to concrete a long vertical cavity in a concrete swimming pool. 1.5 meter height 80-170mm wide and 50-10mm deep. It formed after removing/chisel out wet loose concrete around a heavily leaking crack unsuccessfully patched ages ago. I have no idea what is best for the task to achieve durable strong bond of old concrete to a new one and at the same moment to be suitable to use in swimming pool. After searching internet I consider a few options to do the job. 1. I already purchased 10kg of Quickset Watercrete. It is not enough and I need to buy more and it is quite expensive. Also someone mentioned it is not that strong as GP cement concrete. Also I am not sure about it's adhesive strength to old concrete. 2. To use GP Cement/Washed Sand (1 to 4 ratio), Water and Bondall BondCrete Cement Additive 3. To use GP Cement/Washed Sand (1 to 4 ratio), Water and Crommelin High Performance Bonding Agent 4. Combine either 3 options above with Sika High Strength Epoxy Repair Adhesive Concrete Fix Kit (Sikadur-33) applying on a surface of old concrete. What is a best way to do the job? Thank you in advance. Kind Regards, Yury Re: Concrete pool repair 2Oct 03, 2019 2:27 pm You got any photos... finding it hard to imagine this long cavity Re: Concrete pool repair 3Oct 18, 2019 7:35 am PoolOwners You got any photos... finding it hard to imagine this long cavity Sorry, no photo as a a crack has been patched. I used Lanko 701 Duragrout Structural Grout (class c, expands in two stages) and Lankolatex 751. Davco representative advised to use Lanko 731 Repair Mortar but I preferred the non-shrink grout. Re: Concrete pool repair 4Oct 23, 2019 7:10 pm gag PoolOwners You got any photos... finding it hard to imagine this long cavity Sorry, no photo as a a crack has been patched. I used Lanko 701 Duragrout Structural Grout (class c, expands in two stages) and Lankolatex 751. Davco representative advised to use Lanko 731 Repair Mortar but I preferred the non-shrink grout. has it done the job? Re: Concrete pool repair 5Oct 25, 2019 9:13 am PoolOwners gag PoolOwners You got any photos... finding it hard to imagine this long cavity Sorry, no photo as a a crack has been patched. I used Lanko 701 Duragrout Structural Grout (class c, expands in two stages) and Lankolatex 751. Davco representative advised to use Lanko 731 Repair Mortar but I preferred the non-shrink grout. has it done the job? As for me it has done the job. But I can be wrong as I have no experience in concreting In fact it was a structural crack. I got PFC steel channel 150 * 75 sliced to the staples 10mm thick each and stitched the crack with those staples. Time will show if it was a proper way to fix it or not. 701 Duragrout was a bit slumpy even in plastic consistency but it never been supposed to be used on huge vertical cracks. 731 Repair Mortar is non-slump in vertical and overhead work. Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10414 DIY, Home Maintenance & Repair Hi All, Hoping someone might be be to provide some advice on my ceiling that needs repair. Photos attached, but seems like the alcove (??) is pulling away. Thanks Thomas 0 6555 |
