Browse Forums Pools & Spas Drainage surrounding pool 5Aug 06, 2019 12:57 am Most people get the same sort of strip drain from Bunnings, and they’ll get the galvanised grating dipped or coated to make it look better, that’s the cheap way of doing it, or you can get ones which will take your tile too, but I noticed they don’t feel solid when you walk on them Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12271 2 5838 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3147 |
