Browse Forums Pools & Spas DIY, Home Maintenance & Repair The compression ring at the mains water line's ball valve almost certainly is the problem and a plumber wouldn't be there more than 1/2 hour of which… 6 786 ![]() DIY, Home Maintenance & Repair Polyethylene is difficult to repair due to its carbon-hydrogen internal bond structure. There are plastic repair persons who mostly operate as mobile businesses, have you… 1 1005 ![]() That's an outdoor power point. Note the inlets are facing down meaning gravity stops water from getting inside the PowerPoint. It's totally fine. 1 627 ![]() |
