Browse Forums Pools & Spas 1 Dec 14, 2018 2:50 pm Does anyone know if its still an option to have an operable window with crimsafe forming part of the pool barricade?
My brother in law's block is quite small, so the only way to fit a pool in is if it's 1m from the house. Thanks Re: Window Forming Pool surround? 2Dec 14, 2018 2:53 pm I have found this. Clearly says up the top you can't. But then why does it then describe doors and windows in pool barriers? Only for those who have older pools? Seems logical that you'd be allowed to so long as the window had crimsafe on it. I mean no one is getting through that! Thoughts? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Window Forming Pool barrier? 4Dec 19, 2018 8:40 pm I regularly use crimsafe to secure windows . The other cheaper option is to fit a screw or a window restriction to 100mm opening . Legal in australian standards Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3817 I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9944 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 15111 |
