Browse Forums Pools & Spas 1 Dec 10, 2018 12:29 pm Hi I have a 10 year old cartridge filter (Monarch P4-200) for my 50KL pool. Its not catching the fine particles, I have swapped out some cartridge filters, but thinking it could be an issue with the water bypassing cartridges via internals, either the two filters not mating correctly or an issue with the bottom filter and the center pipe seating with spigot. I have used clarifier in the water to combine the finer particles, but it just goes through the filters and reappears; heres the photos after the third try. I did clean the filters after each try and they do show some signs of dirt but somehow the majority of the particles are getting through the system. Not sure if I should invest in another cartridge filter. Thoughts? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pool Cartridge not working properly? 3Dec 10, 2018 4:52 pm The pool had an algae problem after lots of rain and I shocked the pool. Probably the filter still shows that a bit. But trust me the brown stuff is residue that isn't being picked up by the filtration, even when directly vacuumed. Re: Pool Cartridge not working properly? 4Dec 10, 2018 5:53 pm wander over to trouble free pool https://www.troublefreepool.com/content/ a clean pool you should be able to drop a coin in the deep end and tell if it is heads or tails https://www.troublefreepool.com/threads ... ht=sparkle Re: Pool Cartridge not working properly? 8Dec 10, 2018 8:01 pm yes, join the forum https://www.troublefreepool.com/forum.php i havent been in a pool store in 5 years the water is so clear at night you have to check to make sure the water is still there phosphates are meaningless if the chlorine levels are correct it is an excuse for the pool store to sell you something My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 693 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7536 Okay sorry silly me, my wife has solves the mystery for me. It’s because the labels on the ports are all wrongly positioned by the builder hence it confuses me. 2 1380 |
